| | | Forums66 Topics128,162 Posts1,056,944 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | I have a 1969 C60 Slower then all get out, i want to take the old 4 spd out and put in a five or 6 or 7 speed in, as well as get a long geared rear end with out the 2 speed. can anyone help me out with what i should be looking for.? | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Here are a couple of things that would have been original to your model that you may want to consider for the swap.
Common 5 speeds in C60-C65's were Clark 282 and 285 models. Rear ends are determined by capacity and basically what I remember is that the 15K w/ 2 speed was a vacuum operated Chevy rearend. The 17500, 21K were Eaton electric operated 2 speeds. I doubt you'll find any 21K's in C60's but a ton of them had 17500's. Very common farm trucks with 7K front axle's, 9:00 rubber and 6:50/7:17 rear ratio. Hope this is of some value to you.
ps...you didn't say what your truck now has but the assumption is that it is a single speed rear, (?) The model and ratio may still be visable on the inside of the glove box door. | | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | Thank you for you help. No my truck has an electric 2speed rear.not a vaccum one. I want to make it go faster then 45 mph. and it has a 4speed i think it is not the original. so i need to look for a Clark 282 or 285 tranny then. and i have 9*20 wheels | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Derek,
Before considering another trans, I would first check to see exactly what rear-end ratios you have. A too low gear in high range could possibly be the problem all the long. Try to see if you still have a label on your glove box door for the ratio numbers.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 69chevdump,
There is no question your Eaton two speed rear end is actually shifting into the direct (HI) range!
Stuart | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Do find out what the high side ratio is in the rear, and then use this site for calculating speeds. http://www.drivetraindirect.com/t_gear_calculator.htmIf you know what rear you have you can find out what faster gears are available, and if that's all you need to go as fast as you want. Why don't you want the two speed? Most (if not all) two speed rear axles share a housing with a single speed model, so a single speed center section probably fits in place of your two speed if that's what you want. You may still need an OD to go as fast as you want, but lets do this one step at a time. What engine do you have, and does it have a completely round flywheel housing that the transmission bolts to with 12 bolts? or not? Grigg | | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | thanks bill i will look into that tommorrow. i have a 350 gas engine in it.i dont want to get rid of the 2 speed i just want it to go faster then 45 mpph and not be sounding like its going to blow. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Is it shifting to the high side in the rear? | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Grigg,
Not to answer for Derek, but I went thru step by step details on it with him a short while back and he said he could tell it did shift.
This has been a puzzle with a few of us, that hasn't been solved yet. I believe he either has a very low geared high range rear or a 5-Speed trans that won't go into 5th for some reason.
| | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | Bill, thanks for answering.
Yes that is the truck we are talking about. I have done alot of troubleshooting and for somereason the truck does have a very low rear end but should have a 5 speed but looks like it was switched out for a 4 for some odd reason im checking into the rear gearing soon as i get a chance to get out there. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Hey 69chevdump can you get some good pictures of the transmission for us I am sure I could ID it for you? How many PTO ports dose it have? A swap from a 4spd to a 5spd shouldn't cause this trouble unless the original 5spd was an overdrive and they are rare believe me I have led a long search for an OD.5spd. | | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | I will try to get some for you. actully i had this truck for sale on here and posted 40 some pics. if you search that you may find a bunch of trans pics. i tryed looking for a badge to see what the gearing was in the rear but my truck has no badging except whats riveted in the drviers door. | | |
