8 members (Guitplayer, 78buckshot, Otto Skorzeny, cmayna, Cletus1950, Southerntruck, 1955 1 Series, Wayne67vert), 99 guests, and 1 robot.
Topics128,156
Posts1,056,871
Members48,456
#34093 07/20/2003 1:30 PM
Junior Member
Junior Member
I have a 1949 chevy 6400 that I am trying to get to move on it's own. The clutch pedal goes all the way to the floor. I assume the clutch is stuck. The brake pedal is not moving from the released position. I haven't had a chance to check any thing yet, I just nedd a place to start. All help will be appreciated. Many thanks.
Goggles, a putty knife, a wire brush, and a creeper. Time to get messy. grin
If you haven't already, get a reprint of the shop manual. Then you'll know where the return springs used to be. You might want to disconnect all the linkage to the pedals and see if they still pivot freely at the toeboard.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
Sounds like the master cylinder has possibly rusted in that position. Best bet there (if it is stuck would to replace it with one that is new or rebuilt OR find a decent master cylinder to rebuild.
I think your clutch may be stuck in the release position as well. Look at the linkage to see if it is connected.
Junior Member
Junior Member
Folks, I appreciate you taking time to talk to a rookie. Thanx for the info. Steve Ramsey
Keep us updated on what you find,,, problems or fixes smile
