| | | Forums66 Topics128,131 Posts1,056,722 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34093 07/20/2003 1:30 PM | Joined: Jul 2003 Posts: 6 Junior Member | | Junior Member Joined: Jul 2003 Posts: 6 | I have a 1949 chevy 6400 that I am trying to get to move on it's own. The clutch pedal goes all the way to the floor. I assume the clutch is stuck. The brake pedal is not moving from the released position. I haven't had a chance to check any thing yet, I just nedd a place to start. All help will be appreciated. Many thanks. | | |
#34094 07/20/2003 4:48 PM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Goggles, a putty knife, a wire brush, and a creeper. Time to get messy. If you haven't already, get a reprint of the shop manual. Then you'll know where the return springs used to be. You might want to disconnect all the linkage to the pedals and see if they still pivot freely at the toeboard. | | |
#34095 07/21/2003 1:13 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Sounds like the master cylinder has possibly rusted in that position. Best bet there (if it is stuck would to replace it with one that is new or rebuilt OR find a decent master cylinder to rebuild. I think your clutch may be stuck in the release position as well. Look at the linkage to see if it is connected.
#34096 07/24/2003 2:23 AM | Joined: Jul 2003 Posts: 6 Junior Member | | Junior Member Joined: Jul 2003 Posts: 6 | Folks, I appreciate you taking time to talk to a rookie. Thanx for the info. Steve Ramsey | | |
#34097 07/24/2003 4:10 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Keep us updated on what you find,,, problems or fixes
