7 members (Nick in Manitou, Greg_H, TexasJim50, Otto Skorzeny, GusG, 2 invisible), 115 guests, and 2 robots.
Topics128,089
Posts1,056,428
Members48,443
#340658 11/23/2007 8:31 PM
IM wondering if anyone knows is it a good idea to swap the gear cluster from one rearend to another...I cant get parts intime for sat but I do have a parts rearend thats the same...ie:swap used cluster from one to another and if I can anything I should know first?...? smile
3B Offline
Hy ambear, are we talking about swapping a whole differential assembly, or swapping just the gears?
Was guna do the whole dif but I just finished swaping the gear cluster....thnx anyway
If you swapped the center section of a 55-64 axle with the bolt-in center, no sweat. If you changed the ring & pinion of an integral-carrier axle, good luck! There's about a 1 in 1,000 chance of hitting all the clearances, bearing preloads, and tooth contact patterns right on the first try.
I only swapped the cluster and it was out of my 68 ..exact same rear end...only diff is the new cluster I put in the 65 is posi all done and she drives great..thnx smile
