7 members (55shaker, Hanks custodian, NJC, 3B, Gdads51, Otto Skorzeny, 1 invisible),
209
Mod | | | Forums66 Topics128,086 Posts1,056,098 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | I'm getting ready to install my recently acquired 3 speed w/ OD. I currently have the stuppy short 3 speed HD transmission. I tried to measure it from the bellhousing to the end of the transmission case and got about 12". Can some on tell me how long their 3 speed regular transmission is, because I believe it is the same length as the 3 speed with OD. Or just tell me how long your driveshaft is infront of the carrier bearing. Thanks alot for the help bolters.
58' 3200 235 3-speed/OD
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I come up with 22" from mounting flange to end of tailshaft housing.
Bill Burmeister | | | | | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | When I did the swap into my '61 Apache, I removed the original 3 speed(Muncie) and replaced with the OD. Exact same length, bolts up same way, same spline count on input and output. No driveshaft mods necessary. Plug 'n play as they say:) If you are using a later Saginaw type unit, I believe the spline count on the output is different, you'll need a different yoke. | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Yachtcare, I currently have the Heavy Duty 3 speed. It's short and stumpy so I need to cut down my drive shaft to fit the new OverDrive tranny. It does look like I will need a new yoke for the new tranny, but I have a few lying around and might not be a problem. LONGBOX55, could you measure the front half of your drive shaft, from tranny to carrier bearing, and tell me what you come up with? That would be a HUGE help! Thanks for the info so far fella's.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Ohh, no can do, buddy. Mine doesn't have a carrier bearing, I've got a 1 peice driveshaft. Mine had the std 3 speed in it originally.
Bill Burmeister | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Well I appreciate it. I guess I can go to a single piece drive shaft, I was just trying to reduce the amount of down time on my truck. I appreciate all the help fella's!!
| | | | | Joined: Oct 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 52 | there is two tail housings for that trans..one is a short guy the other is about 6 inches longer...maybe you can swap the tail housing for a shorty?
| | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | You probably won't be able to use a one piece driveshaft. If your 3200 has a 8' bed it probably needs the 2 piece driveshaft. The 55-57 3200's had a 7' bed and had a one piece shaft with the standard 3 speed. The last time I had a custom driveshaft made up the driveshaft shop said to take the dimensions as follows: Insert the front splined yoke as far as it will go into the trans - pull it back out 1 1/2 inches - measure from the C/L of the front U-joint to the C/L of the rear U-joint (in your case the rear U joint of the front shaft). Give them that dimension and they will make up a shaft.
The standard 3 speed was available with a long or short tailhousing depending on the year. There is no such thing as a "short" tailhousing Overdrive.
The Warner HD trans is a completely different animal and nothing from the standard 3 sp or OD transmission will interchange with it. Fred
