1 members (JW51), 137 guests, and 2 robots.
Topics128,049
Posts1,055,741
#34003 04/17/2005 5:53 PM
Junior Member
Junior Member
I have a 41 1/2 ton rebuilt master and new wheel cylinders new brake lines. the brake peddle is getting harder and harder to the point that it starts to drag the breaks and activates the hydrolic brake switch. Thanks in advance for any suggestions.
41 1/2 ton
don't force it get a bigger hammer
#34004 04/17/2005 10:57 PM
Did you replace all the rubber lines? Could be the master is not letting the fluid to return.
#34005 04/17/2005 10:57 PM
I had a similar problem that was caused by the MC plunger not coming out far enough to expose a pressure relief opening. I backed my plunger out 1/6 of a turn and the problem was solved. I was amazed that only 1/6 of a turn could make that difference.
#34006 04/17/2005 11:00 PM
Sounds like Wally has the right idea. I did not think of that.
#34007 04/18/2005 12:39 AM
You don't have enough pedal free play to compensate for the heat expansion. Does the brakes go back to feeling normal when the truck has sat for a long while?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
