| | | Forums66 Topics128,109 Posts1,056,269 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 8 New Guy | | New Guy Joined: Jan 2007 Posts: 8 | Help! When I turn the hearter on it seems to be blowing antifreeze onto the windows fogging them up. What do I need to look at? 66' C10 w/350, thrift air | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | electroman,
This is the classic sign of a leaking heater core. I would check the hose connections where they attach to the core..sometimes they will drip down inside and mimic a blown core, but again, it is usually bad news.
Has anything leaked out of the heater compartment onto the carpet or mats?
Stuart | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Ditto Stuart, every time I've experienced that it was a failed heater core. You can try some stop leak for a temporary fix but be aware that if your radiator passageways are partially plugged now, adding stop leak can finish the job.
