5 members (Donf, Shade Baby, sron48, Jon G, Bill Hanlon), 141 guests, and 0 robots.
Topics128,105
Posts1,056,208
Members48,436
#339322 11/20/2007 5:49 AM
Help! When I turn the hearter on it seems to be blowing antifreeze onto the windows fogging them up. What do I need to look at? 66' C10 w/350, thrift air
electroman,
This is the classic sign of a leaking heater core. I would check the hose connections where they attach to the core..sometimes they will drip down inside and mimic a blown core, but again, it is usually bad news.
Has anything leaked out of the heater compartment onto the carpet or mats?
Stuart
Ex Hall Monitor
Ex Hall Monitor
Ditto Stuart, every time I've experienced that it was a failed heater core. You can try some stop leak for a temporary fix but be aware that if your radiator passageways are partially plugged now, adding stop leak can finish the job.
