| | | Forums66 Topics128,181 Posts1,057,174 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 120 | I finished my metal bed floor install on Ol Yeller. It took 15 days from finding a donor bed to completion. I really like the look and functionality. (Apologies to the wood bed purists). The donor bed floor came from a '77 dually. This is the first time I have cut metal (without explosives). Here is a short link: Photobucket | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | I am one of those wood bed purists, but I'll tell you that your bed is a beautiful installation. Looks like a factory job, and my compliment has nothing whatsoever to do with your stated explosives experience. I don't think I've welcomed you to the board, so here it is. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | That is a great installation. Looks factory. Did you remove the entire bed(sides,ends) or just raise it for the install.And that certainly beats just laying a piece of steel over any rotten wood like so many do.
Drew
| | | | | Joined: Jun 2007 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 120 | Thanks for the welcome. This site has been incredibly useful and informative. This is my first old truck experience and my wife thinks that we should start another even though this one is still a work in progress. | | | | | Joined: Jun 2007 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 120 | Drew: Thanks for the positive feed back. I had to replace the front bed panel and sill as it was rusted through. I removed only the left side and fender as a unit. I had to tilt the new floor to slide under the ell brace on the right side. All the original cross sills remain in place, in case I decide to return to the wood bed. | | | | | Joined: Oct 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 52 | nice clean job good work...I still like my wood bed incase i break down in the middle of no where i can scrounge up some grubs to eat...:) | | | | | Joined: Jun 2007 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 120 | I live in the desert. If I break down, road kill cooks up fast on the portable grill! | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Mine will truly not set well with the Wood Bed Folks ...it is a 1/4" thick steel plate ! ...lol I need the weight over the rear axle. P.S. Welcome to the Bolt !!!! | | | | | Joined: Jun 2007 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 120 | SW Radial, There are a couple of guys here in town that did suggest diamond plate. Too fancy for Ol Yeller. But on a tricked truck it might look good with other bling. | | |
