1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | Has anyone rigged up something to "bump" a 235 with a foot stomp starter? Just want to be able to turn the engine over from under the hood, not really wanting to start it. It doesn't look like something that can be done "electrically", or can it? The starter pedal seems to make it an all "mechanical" setup.  Thanks, Ed | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Ed,
I have seen broom handles, big sticks and long screwdrivers all mentioned here as a mechanical means to turn the engine over from under the hood.
Stuart | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It's strictly mechanical, but there's an easy way to bump it over. I just used a large screwdriver on the linkage on the bellhousing, just inboard of the starter. Just pull down on the screwdriver pivoting it off the toeboard. I put a shop rag over the end to keep from gouging the paint.
Bill Burmeister | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | What I do on the 216 is unhook the return spring and then take the linkage that pops the forks out of the way and mash it against the button.
Works a treat.
If you don't unhook the spring, it's hard on your forearms, but it'll still work. | | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | That's the direction I was going, just didn't release the spring. Thanks to all for the replies, I'll go make it work  | | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | Check out Vehicle of Victory.com, He sells a bar for a remote foot operated starter.
JOhn Gott 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
