8 members (Tyler Watts, Hotrod Lincoln, Joe H, Gray_Ghost, Forty9, cmayna, JW51, NJC), 82 guests, and 4 robots.
Topics128,064
Posts1,055,860
Members48,428
Has anyone rigged up something to "bump" a 235 with a foot stomp starter? Just want to be able to turn the engine over from under the hood, not really wanting to start it. It doesn't look like something that can be done "electrically", or can it? The starter pedal seems to make it an all "mechanical" setup. ohwell Thanks, Ed
She's one 55 year old with a spare tire that looks good!
It's not rocket surgery. . . .
http://www.picturetrail.com/fredoly
http://www.cardomain.com/ride/2412127
Ed,
I have seen broom handles, big sticks and long screwdrivers all mentioned here as a mechanical means to turn the engine over from under the hood.
Stuart
It's strictly mechanical, but there's an easy way to bump it over. I just used a large screwdriver on the linkage on the bellhousing, just inboard of the starter. Just pull down on the screwdriver pivoting it off the toeboard. I put a shop rag over the end to keep from gouging the paint.
Bill Burmeister
What I do on the 216 is unhook the return spring and then take the linkage that pops the forks out of the way and mash it against the button.
Works a treat.
If you don't unhook the spring, it's hard on your forearms, but it'll still work.
That's the direction I was going, just didn't release the spring. Thanks to all for the replies, I'll go make it work thumbs_up
Check out Vehicle of Victory.com, He sells a bar for a remote foot operated starter.
JOhn Gott
1942 G5106 1.5-ton Chevy cargo dump Gallery page
Old Dominion Stovebolt Society
T/Sgt. Gott (28 years of service with the USPP)
1940 Chevy G506 4112 cargo dump
1942 Diamond T G509 969A 4 ton wrecker
1942 Ward LaFrance G116 series 2 10 ton wrecker
1944 Ward LaFrance G116 series 5 10 ton wrecker
1931 Ford AA with a WEAVER crane
1944 Sterling HC 165 tractor
1944 Autocar U7144T w/ 10 ton trailer
