1 members (JW51),
96
0
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 102 | I am in the tear down process of a 1961 Apache short bed step side right now and am considering a shop manual purchase. As always, I'm hoping that this community of stovebolters can point me in the right direction. I recently picked up the assembly manual off ebay but I'm looking for a manual that will give me specifics of bolt sizes, torque specs, etc. Is the shop manual with supplement the best way to go or is the Truck Shop Manual CD Rom the way to go through LMC? Input appreciated.... | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | You can get reproduction shop manuals from most of the specialty aftermarket suppliers. Generally from $25 to $30. I like a manual that I can set on the bench to look at. Of course you can always print out pages from a CD and accomplish the same goal. Either way it's important to have this kind of info to help with your project. Fred
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you go with the printed manual, make sure to check if the prior year manaual is required or not. Sometimes, if the bodystyle was a carryover, the manual from the prior year was used and a suppliment manual was published that only covers any changes in specs or new options. I'm not sure on the '61, but a couple of examples would be the '56 and '59, both need the prior year manual to be complete.
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I agree with Fred, I have both the manual and the CD. I think I used the CD once. It is much quicker to grab the book than go to the computer and try to print out a picture or two.
~Jim
| | | | | Joined: Oct 2007 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 102 | Thanks folks. I just ordered the shop manual and the 1961 supplement from LMC. 2nd order in a week. They're gonna love me.....HA | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | You did the right thing. Having separate sources of info gives you you the bigger picture. You should also get the sales brochure. They (LMC or most of the other vendors) also have books on chevy truck history that I have found useful. | | | | | Joined: Oct 2007 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 102 | Thanks Bigmacdaddy, I will add that in my next order from LMC. I almost picked them up last night but was caught up in the decision to buy the wheel dollys. Thank again. | | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | Hey if your gonna get wheel dollies, let me share my experience. I bought two pair from Harbor Freight and while I could move the light rear end of my truck around, there was no way, repeat no way the front was going anywhere with one 250 lb man pushing on it. I even tried jacking it up to align the casters in the desired direction. Nada. BTW, I have a 235 under the hood, not any V-8 and was on concrete. I just think the HF are junk. I have contemplated using come-alongs or winches to move it. PITA.
Sorry for stealing the tread, but it seemed about done. I have CD manuals for the Lincoln & F**D, but paper for the Chevy's. I prefer paper.
| | | | | Joined: Oct 2007 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 102 | 57_StepSide,
No apology for thread stealing here. That is exactly the input I come here to read about. Hopefully the LMC dollies are better quality. I will report back. On the Harbor Freight topic, I've experienced the same issue with a parts cleaner replacement pump. 3 attempts later, I gave up and threw the Master Catalog in the trash. I am not typically frustrated that easily but after 3 times, I was done. Thanks again for the feedback.
NorthDM | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Here is where I like to buy my manuals. http://www.gregsonline.com/ | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Harbor Freight is CRAP. You must be very careful what you buy there. NorthDM I will be making the wheel dollies buy soon so will be watching for your results on the LMC buy.
~Jim
The LMC wheel dollies came in tonight and I put them together, jacked the truck, placed them underneath and "VIOLA", they work awesome. I did take a moment to clean the floor up a bit of any debris and gave er a shove. It actually travelled over 2 feet unassisted so keep your hands on your ride when you do this. HA.
2nd order from LMC, happy both times. So far so good.
NorthDM
