2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#3386 07/06/2004 6:36 AM
Where online is a good place to purchase a radiator. How many rows do I need. I have a 350 and hope to have a/c eventually.
Thanks Brady Eldridge
#3387 07/06/2004 7:34 AM
Hey, Brady
I have a 350 in my truck. It had a 2-cell radiator with no shroud, and the fan was sitting low ... I put AC in and the truck would overheat; couldn't really use the AC ... in fact, on Summer days, it would overheat if I wasn't moving, even without the AC being on.
So, I put a Walker Z-Cool, 5-cell radiator in with a 16-inch electric fan and now I never overheat.
grin
You can see my radiator install notes Here.
Next ... I noticed my voltage gauge hitting the basement whenever the electric fan would kick in -- turns out the wiring was done poorly ... so I wound up rewiring my engine area, which made a wonderful difference! You can see that info Here ... and you can see how I wired up my electric fan (with two relays) Here.
PS -- You can buy radiators from Summit or Jegs
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#3388 07/06/2004 3:25 PM
Brady-
Many distributors for old trucks have replacement radiators. As Alan noted, they generally will have plenty of capacity. One thought is whether you have an automatic tranny with need for a cooler. That's one option you can look for in purchasing a replacement.
These replacements run ~$250-$300. While used radiators are out there for much less, they really vary in the ability to hold pressure (I own two ebay leakers!). You can have an old one re-cored if you want old metal showing in the engine bay.
#3389 07/06/2004 7:44 PM
Have you checked with a local radiator shop? A lot of them will do custom work for the same price as you can buy one on the net & pay shipping.
Fred
52 3600
69 C-10
#3390 07/06/2004 8:32 PM
I have 350 in my 37 pickup. I found a shop that had a new core which would fit my original top and bottom. We did have to cut out the top "neck" and replace it so I could run a modern pressure cap. All in all the shop charged me $265 and it was a job well done. I then put on an aftermarket 16" fan with a Pusher electric fan I can cut on when needed.(parades etc). It still gets a little warm at times but not much.
It sure beat a $525 aluminum from Griffin!! It also depends on what you do to the 350. Some with HP parts run a little warmer than stock so take all things into consideration. If you have the room add a shroud and you should be fine....under "normal" circumstances!
#3391 07/07/2004 3:44 AM
As 51PhatBoy pointed out, it's a good idea to include a tranny cooler in your purchase, as I did.
I had a side-mounted trans-cooler in my old setup and it was right next to an exhaust pipe -- worthless!
Also, be careful what kind of cap you put on the new rad ... with an old engine, you might not want more than a 7 lb. cap ... to avoid putting too much pressure and creating problems with your engine.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
