Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (ShopRag, Otto Skorzeny, Gdads51, Hotrod Lincoln), 57 guests, and 1 robot.
Topics128,009
Posts1,055,291
Members48,419
#33853 07/10/2003 12:21 PM
I noticed while checking where the oil line goes
through the block that feeds the rockers..there
are othere holes on each side where this line
goes through...what are they for?
1946 chevy 1/2 ton panel
1937 ford coupe
#33854 07/10/2003 12:53 PM
The one forward of the oil line is for the return line on the exterior oil filter. If no filter the hole just has a pipe plug in it. The hole towards the rear is where the fitting for the oil pressure guage line goes. If running a filter,there is a brass tee there. No filter, a brass elbow for the oil pressure guage.
#33855 07/10/2003 3:25 PM
I don't know..brjr51
I don't see any threads on the inside of these
hole's in the block?
1937 ford coupe
#33856 07/10/2003 3:48 PM
I hope were talk'n about the same side (pushrod)
side..I believe these hole's are covered by the
side pan (pushrod pan)
1937 ford coupe
#33857 07/13/2003 2:20 PM
Sorry, me bad. I was thinking you were talking about the other side of the block. If you mean under the side cover, I believe those holes are there for the oil to drain back to the pan.
