| | | Forums66 Topics128,043 Posts1,055,524 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 67 | Can some one please help me find out what my engine is. It is in a 1 ton 1947 first series. The casting number right behind the distrubuter is T2188C1 the C could be a 6. The numbers are not in a real straight line as on other motors. I have tried looking around through codes on other sites and here but have not found on with the number. This may not be the orginal motor I dont know. I was told it was a 261 but that it had babbit bearings. The engine only has about 15 psi of oil pressure so I thought it was a 235. Please any help would be great. Thanks Matthew
1947 1Ton stepside 1962 K20 Fleetside 1962 C40 12' flatbed 1963 C10 Stepside 1963 C20 Fleetside 1965 C10 Stepside (Daily Driver) 1973 C20 Stepside fire truck 1973 C50 Utility truck Houston Power & Light
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy chevycountryboy, the numbers you are refering to are the engines serial number, I don't know of a referance to check those. Casting numbers are raised numbers, not stamped into the block, if you could find some casting numbers on the block and the head we could probably help you to identify what engine you have, hope that helps. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Also look on the pan just under the distributor, if it's a 235 it could have '235' stamped into the side of the pan. But the casting numbers are the best to i.d. the motor. | | | | | Joined: Aug 2007 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 67 | Thanks so much guys will look for casting numbers
