1 members (Materman),
115
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 141 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 141 | Thanks for the help on the tar. The next area I am working on is inside the cab. I just finished sanding and grinding down the floor and there are some areas that have some slight discoloration adn texturew where the surface rust was. I found a product called Kleanstrip that I was going to spray on before I primed it. Can someone advise the best product for this??
PS I cut out the major rust damage and I am welding in patch panels this is for some surface rust.
Thanks, Brian | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Eastwood sells a excellant Rust killer for under your new paint ..works great on rough surfaces like a floor pan . Tim | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | In cases like this I have used eastwoods "metal ready" and I'm pleased with it. I assume there's no paint on your floors. After that treatment I spray with Southern Polyurethanes epoxy primer. Actually I'm doing mine now After I weld in a patch panel. The "metal ready" will remove the rust discoloration in 15 miutes and leave a phosphate coating to help prevent future rust.
Just my $.02
Keith | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Metal Ready is actually manufactured by POR15.
I myself would recommend the POR15 products.
