5 members (Lightholder's Dad, 3B, carbking, Bill Hanlon, Cletus1950), 79 guests, and 4 robots.
Topics128,181
Posts1,057,177
Members48,465
I've searched the forums a couple of times for a part number for an oil filter cartridge for a 216. On one search I found info for a NAPA 1100 cartridge which I bought. It turns out that was too big. Anyone know of one that might fit? Thanks.
It's a small world, but I wouldn't want to paint it.
That's the right element for the standard AC filter. If it doesn't fit then you have an oddball filter canister and you might get some help by posting a picture of it.
Your AC filter accessory or option should look like one of these, scroll: http://rides.webshots.com/photo/2447023530098611668jJjVWf
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I'm glad this question was posted, because now I'm really confused.
My 1946 216.5 C.I. Chevrolet pickup has no oil filter on it at all. There is also no reference in the 1946 Shop Manual about an oil filter. Can this be true? If not, can someone help to guide me through the installation of one? To me it just doesn't make any sense that this engine wouldn't have an oil filter.
"Lucille" ..... Proud Member of the "Southern Stovebolts"
David Wolff
1946 Chevy 1/2-ton
Many items vehicles come from the factory with and are not an extra charge were in fact originally an option. I can remember my old 51 came without a defroster, a 60 Ford truck came without a heater. Those and many other "options" became regular equipment as completion pushed. I also had a 55 Chevy two door that came without an oil filter. It was an option but a good idea to add one when making the purchase or later on when you could afford it.
~Jim
My 1950/1951 Original salesman guide with handwritten notes shows that on most models it was option 237B with an installed price of $10.40. So if you wanted an oil filter it was not standard equipment you had to buy it.
I guess this makes a good case for the edit function Brad! A good example or how carfully we need to composer a reply.
By standard I did not mean that it was a standard item on the vehicle. I meant that the standard oil filter that was offered as an accessory or option would have been and AC filter.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Chevs of The 40's has a filter that will fit. It is an AC #P203. They say it will fit '39 - '54 Chev vehicles. So I guess it wasn't 'the standard' cartridge I needed. Thanks for your input.
Ex Hall Monitor
Ex Hall Monitor
I took my canister to my FLAPS & they matched it up with an element. The part # of mine is 51006 by WIX.
Rusty,
That is the correct AC Delco Part Number for that filter. (At least, the one that fits in my truck. YMMV.)
For future reference, you can also pick up a Fram C3P. My FLAPS has them, and I saw one in Advance Auto (my backup FLAPS) the last time I was in there looking for fuel filters.
Edit:
Here are some of the common FLAPS brands and part numbers for that filter cartridge:
AC Delco
P203
P204
Carquest
85010
85026
NAPA
1010
1026
Purolator
P70AC
L20701
Quaker State
QSC3
L20701
Shell
L20701
Valvoline
LC3
Warner
P3
WIX
51010
51026
For the rest of the cross referenced numbers, visit Fram's Website and look in the product catalog. Search for C3P.
Interestingly enough... If your FLAPS doesn't have it, try your local tractor or farm equipment dealership. It seems that everyone and their brother used that cartridge at one point or another.
My 50 3600 216 has an accessory by-pass oil filter and some of the printing is still on the canister and it reads FRAM. I threw away the cartridge before measuring it and now I need to find another one.
Professional Novice
The filter element that fits my '48's housing is a NAPA 1006. I think it's the same as the Wix filter that Tiny uses, since the part numbers are identical, except for the first character.
It measure 4 1/8" diameter and is 4 13/16" tall, give or take a hair.
cool
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
I'll have to try that one on my next oil change. grin
I was at the Chev dealer for an unrelated part and the parts guy, who has been selling parts for many years, said people used to put rolls of toilet paper in the filter cannisters. I didn't think to asked but I assumed they used 2 ply!!
I dunno, Rusty. That sounds like a crappy idea to me.
thumbs_up
1948 Chevy 1/2-Ton
Apprentice
Apprentice
It was not unusual to have a "filterless" engine back then. I have a couple of 216s here with no filter and one that does. I guess that might explain why the engines wore out quickly. Go figure.
Cartman
Today I took my oil filter canister to the local NAPA store to get a filter. Actually none of the writing or labels are legible, but for some reason I thought it was a Fram. It is about 4 1/2" I.D. and the straight part is about 5" tall. The cone bottom is folded rather than smooth. It looks like some pictures I have seen that were identified as Fram. The NAPA filter that fit perfectly is a Napa Gold 1006. This cross references to a Fram C4. I found this page on the Fram site that list all the applications for this filter and the competitors part numbers. I hope others find this useful. wink
Sorry, blush this Honeywell page is not as user friendly as I thought. :blat: You have to select the Fram parts link on the lower left. When the new page pops up you can enter C4 in the Fram part number block and get the application and competitor info I want you to see. grin Maybe it will help somebody someday?! smile
Professional Novice
