9 members (John Dlugos, Buckeye998, Gray_Ghost, Gdads51, dt235sd, rfs56trk, BCBill, Otto Skorzeny, Dusty53),
236
0
Mod | | | Forums66 Topics128,101 Posts1,056,172 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 33 Apprentice | | Apprentice Joined: Oct 2007 Posts: 33 | With all due respect to the traditionalists, I have purchased an aftermarket firewall,toeboards and front floor from "bitchin products" through a local supplier. I have received the items and foresee little problems in the install. I am considering going with the bitchin inner fender for the smooth look along with the rad support system they make. My original rad support has been welded on from an accident and looks to be more work than worth. Also, my original fenders were both damaged in accident and require about 40 hours of work to make decent and no quarantees on rust coming back. I am contemplating buying the Taiwan front fenders. Does anyone no how they look for shape and quality? How do they fit? Is there anyother supplier? Cheers | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | WWG Great choice with Bitchin. I don't think there is anyone out there producing sheetmetal that is more perfect for replacing bummed out stuff. Don't know anything about Taiwan stuff.
~Jim
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | consider locally made fiberglass unless steel is the way you want to go. Saves on the weight and not as expensive. | | |
