8 members (delwrench, crenwelge, 2-Ton, Cletus1950, Jay R, Hugh63c10, 1955 1 Series, amtrakjoe), 338 guests, and 6 robots.
Topics128,159
Posts1,057,027
Members48,460
What would be the possible ratio options? One? More than one? 3.73?
3.73 sounds credible. Could also be 4.10.
1951 3800
-hotshoe
If the truck can go about 60 before it sounds like it's revving too much, it's probably a 3.73.
To find out for sure, besides taking off the rear cover, you could raise the truck, spin the wheels and count the driveshaft turns (altho a non-posi procedure works different), and there also should be a code stamped on the rear you could decipher.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Non posi, I believe you double your result.unless you turn both wheels at the same time.
Right, that's the way I have learned it and since have heard others verify it, when turning one wheel anyway. Double what you get.
GMC 9500 Fan
Detroit Diesel Fan
my 66 GMC was ordered with a 3:73 posi
Another quality post.
Real Trucks Rattle
I believe our site sponsor provides some info about ratios for this year under axle codes.
http://www.americanclassic.com/paint.htm?p1=axles
I inquired about a 12 bolt rear end for sale recently and was told there was a sequence of HQ 1215 W on the axle. I interpreted this as a 1966 3.73 ratio built on December 15 at Warren, MI if I recall correctly.
Another vendor provides a list of RPO codes for rear ends on their site. The RPO numbers may be found on a sticker in your glove box?
http://www.drivetrain.com/gm8.875trk.html
http://www.drivetrain.com/GMtrkratio_posidata.html
Hope this helps.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
The available choices that year were a 4:11, 3:73 or a 3:07 in the 1/2 ton truck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Thanks for all the great info!!!!!!!!!1
It does feel pretty comfortable at 60 but I don't like to take it over 65. I've put taller tires on the rear to help a little.
