1 members (1 invisible),
368
Mod | | | Forums66 Topics128,162 Posts1,057,043 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 41 New Guy | | New Guy Joined: Jul 2007 Posts: 41 | What would be the possible ratio options? One? More than one? 3.73? | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | 3.73 sounds credible. Could also be 4.10. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | If the truck can go about 60 before it sounds like it's revving too much, it's probably a 3.73.
To find out for sure, besides taking off the rear cover, you could raise the truck, spin the wheels and count the driveshaft turns (altho a non-posi procedure works different), and there also should be a code stamped on the rear you could decipher.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Non posi, I believe you double your result.unless you turn both wheels at the same time.
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Right, that's the way I have learned it and since have heard others verify it, when turning one wheel anyway. Double what you get.
| | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | my 66 GMC was ordered with a 3:73 posi
| | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | I believe our site sponsor provides some info about ratios for this year under axle codes. http://www.americanclassic.com/paint.htm?p1=axlesI inquired about a 12 bolt rear end for sale recently and was told there was a sequence of HQ 1215 W on the axle. I interpreted this as a 1966 3.73 ratio built on December 15 at Warren, MI if I recall correctly. Another vendor provides a list of RPO codes for rear ends on their site. The RPO numbers may be found on a sticker in your glove box? http://www.drivetrain.com/gm8.875trk.htmlhttp://www.drivetrain.com/GMtrkratio_posidata.htmlHope this helps.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The available choices that year were a 4:11, 3:73 or a 3:07 in the 1/2 ton truck, Scott | | | | | Joined: Jul 2007 Posts: 41 New Guy | | New Guy Joined: Jul 2007 Posts: 41 | Thanks for all the great info!!!!!!!!!1 It does feel pretty comfortable at 60 but I don't like to take it over 65. I've put taller tires on the rear to help a little. | | |
