2 members (Rusty Rod, LAROKE),
103
Mod | | | Forums66 Topics128,193 Posts1,057,260 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 37 | I'm not sure if there is a problem with the wiper motor, or the way it's hooked up to the manifold. It appears the hose goes from the wiper motor to the intake manifold.
Anyone have a photo I can reference? Thanks, | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | That is as it should be. If your motor isn't working, the first thing I'd check is if your hose is collapsed inside. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I tested my wiper motor before I had the truck together. I took a funnel, taped a small vacuum hose to the end, turned on the vacuum cleaner and stuck the mouth of the funnel on the metal tube that the attachments go on. The vacuum keeps everything in place. I was able to try all the different functions of the unit. | | | | | Joined: Jun 2005 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 37 | Thanks for the replies gents. It turns out that the hose was plugged up pretty good. Replaced the hose and the vacuum greatly improved. However the wipers moved slowly, very slowly. I took out the wiper motor and reattached the vacuum hose to the motor and it seemed to work perfectly.
When I installed the motor back in the dash the wipers were still moving very slowly. Is there something I'm missing here, perhaps some sort of adjustment with the arms? | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If it works fine out of the dash but poorly in place, it is likely that the seals inside the motor are dried out and blowing by. There needs to be enough spring pressure on the arms to hold the wiper blades against the glass, so it will take some force. The motor has to have good enough "compression" to pull against the wiper arms. Yours either needs lubrication or rebuilding.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | My shop manual says to wet the windshield when you do a wiper motor test. You can't expect to sweep dry rubber across dry glass without resistance. For a true test, get out the garden hose and see how it performs. If it is still sluggish, get out your wrenches. Otherwise, wait for the next rainstorm. No matter what the results, you might as well give it a wash while you're at it.  Bill | | | | | Joined: Sep 2007 Posts: 31 New Guy | | New Guy Joined: Sep 2007 Posts: 31 | I had the same problem with my wiper motor. Had it out of the truck and everything worked fine and I put it back under the dash board and the thing would barely move the linkage that connected to the wiper arm studs. I'm probably just gonna bite down really hard and buy an electric conversion. Unfortunately they're about 190 bucks from what I've seen. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Make certain you use vacuum hose and not windshield washer hose. The thin wall of the latter will cause it to collapse. | | |
