| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | I'm rebuilding my bed in my 1952 1300. I don't have a lot of money for this so I'm just using fir planking for now. When I was drilling and installing the carriage bolts I was having a heck of a time trying to get the washer on the bolt before the nut in the limited space in the support rails. I ended up using a big magnet on the top of the bolt then the washer would stay on the bolt while I put the nut on. Hope this helps somebody as it sure made the job more enjoyable. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Good idea I was wondering how I was going to do that. Thanks for the idea that is really clever. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Great idea. Thought mine was until I read yours. I used masking tape to hold the washer to the nut and put it in the end of a long socket. Someone held the bolt from above and I tightened. Tape comes off easily. | | |
