Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Wickedbass, 55shaker, lumbersawyer, Jaison, Donf, 1955 1 Series), 40 guests, and 2 robots.
Topics128,010
Posts1,055,298
Members48,419
#33363 04/25/2002 4:27 AM
My truck just sucked a ring and when it did it stopped running (it was out of gas i think) now it just trys to start and almost does but it wont start i can prime it and it almost does or pump the accelerator and it tries to start but wont run could this be a fuel line clog? a carbuerator
problem? any help would be awesome thanks
Hudson
#33364 04/25/2002 4:50 AM
Red dot, center of chest ...
Where in Texas are you? I'm in Dallas, and we've got a bunch of Stovebolters around this area. There might be somebody that could come by and help you out.
I have no idea what you mean by "sucked a ring".
The symptoms you describe could be almost anything. It's hard to say without putting my hands on the truck, but I'd check to make sure you've got good spark and shoot some carb spray down the carb. If it won't start then, it'll take more work to get it goin'.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
#33365 04/25/2002 5:07 AM
If you ran out of gas it could be a couple of things. First, I would check the fuel filter. then look inside the carb. Could be water in the bowl. Does the fuel pump work? Disconnect the fuel line to the carb, stick it in a pop bottle that you can see through, and have someone crank the engine. If not, check the flow out of the tank and the line from the tank to the pump. And be sure to check to see if you have spark.
Fred
52 3600
69 C-10
#33366 04/27/2002 4:53 AM
glory be it is alive! Enough ether and anything will start. But i found out it is not the ring in fact it is a blown head gasket instead ( a whole lot easier to fix) well thanks for the help and i live in fort worth thanks again
Hudson
#33367 04/27/2002 7:27 AM
You're right....there are a lot of us around here. I would like to come to one of the get togethers, but my '65 is in such pitiful shape that I'd be ashamed to show my face!
Beat it to fit...Paint it to match.
#33368 04/27/2002 2:26 PM
Kip Offline
Why Mr.Guru is your truck a phord? Everybody on this board digs all GM trucks (well maybe not the "Luv"). Yours is just in process. You know what? all of our trucks are "In Process". Are We ever Finished?
Adios, Kip
Write On The Cross At The Head Of My Grave
To Whiskey And Women Here Lies A Poor Slave
#33369 04/27/2002 3:16 PM
Fred T. says
Quote
I would advise, not at the same time...
:rolleyes:
54 3100 with 235
62 flatbed dump C60 with 261
