| | | Forums66 Topics128,010 Posts1,055,303 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33363 04/25/2002 4:27 AM | Joined: Apr 2002 Posts: 42 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 42 | My truck just sucked a ring and when it did it stopped running (it was out of gas i think) now it just trys to start and almost does but it wont start i can prime it and it almost does or pump the accelerator and it tries to start but wont run could this be a fuel line clog? a carbuerator problem? any help would be awesome thanks Hudson | | |
#33364 04/25/2002 4:50 AM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Where in Texas are you? I'm in Dallas, and we've got a bunch of Stovebolters around this area. There might be somebody that could come by and help you out.
I have no idea what you mean by "sucked a ring".
The symptoms you describe could be almost anything. It's hard to say without putting my hands on the truck, but I'd check to make sure you've got good spark and shoot some carb spray down the carb. If it won't start then, it'll take more work to get it goin'. | | |
#33365 04/25/2002 5:07 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you ran out of gas it could be a couple of things. First, I would check the fuel filter. then look inside the carb. Could be water in the bowl. Does the fuel pump work? Disconnect the fuel line to the carb, stick it in a pop bottle that you can see through, and have someone crank the engine. If not, check the flow out of the tank and the line from the tank to the pump. And be sure to check to see if you have spark.
Fred 52 3600 69 C-10
#33366 04/27/2002 4:53 AM | Joined: Apr 2002 Posts: 42 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 42 | glory be it is alive! Enough ether and anything will start. But i found out it is not the ring in fact it is a blown head gasket instead ( a whole lot easier to fix) well thanks for the help and i live in fort worth thanks again Hudson | | |
#33367 04/27/2002 7:27 AM | Joined: Apr 2000 Posts: 6 Member | | Member Joined: Apr 2000 Posts: 6 | You're right....there are a lot of us around here. I would like to come to one of the get togethers, but my '65 is in such pitiful shape that I'd be ashamed to show my face!
Beat it to fit...Paint it to match.
#33368 04/27/2002 2:26 PM | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | Why Mr.Guru is your truck a phord? Everybody on this board digs all GM trucks (well maybe not the "Luv"). Yours is just in process. You know what? all of our trucks are "In Process". Are We ever Finished? Adios, Kip
Write On The Cross At The Head Of My Grave To Whiskey And Women Here Lies A Poor Slave
#33369 04/27/2002 3:16 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Fred T. says If not, check the flow out of the tank and the line from the tank to the pump. And be sure to check to see if you have spark. I would advise, not at the same time... :rolleyes:
54 3100 with 235 62 flatbed dump C60 with 261
