5 members (Forty9, dt235sd, FAST55, Otto Skorzeny, 1 invisible), 81 guests, and 1 robot.
Topics128,050
Posts1,055,754
#33350 07/25/2003 4:36 AM
Junior Member
Junior Member
hi all,
thanks for the welcomes on my intro
here comes the first question-my truck is a 51 161"wheelbase which im pretty sure is a two ton,has 20"rims-Just today i noticed there are no shock absorbers!
there are also no brackets or obvoius holes where brackets were....did the big ones not use shocks??maybe they were optional?it was delivered new here by holden (GM in australia)
ive only driven it around a paddock so far, seemed ok..if no shocks-good!one less thing to buy!!
havin a party tommorow and 'the king' as ive named the big 51 will be doin hay ride duty for the kiddies-brm brmmm!
grin
#33351 07/25/2003 4:39 AM
My 1955 GMC Series 500 has no shocks,but I do have Torque rods on the rear.Its a single axle truck,big-un Biddaboy
1956 GMC TF 1/2 ton
1955 GMC 500 model (Gumby)
#33352 07/25/2003 5:05 AM
Anonymous
Unregistered
Anonymous
Unregistered
My 52 4400 has after market shocks ala bubba. Someone hacked a pair onto the front axel and they seem to work ok. I can snap a picture if you are interested. They are ugly and I don't know if they make any difference (the truck has excellent road manners, but I hardly ever drive it on the road)
Ken
#33353 07/25/2003 7:53 AM
My '55.1 GMC 250 panel has no rear shocks or mounting brackets. It's choppy with no load, and I've got to be very careful not to send the rear tires into a low orbit on bumpy roads. Toss a few hundred pounds over the rear axle and it rides like a Cadillac on Prozac.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#33354 07/25/2003 8:42 AM
These trucks were considered too slow to bounce and didn`t need shocks grin
Originally none on the truck from the factory.
#33355 07/25/2003 10:53 AM
My 45 2 ton had wasted single action lever shocks on the front ,none on the back.It was easy to adapt front shocks from a 70-80's Chevy truck, welded up some brackets.Rides the same but maybe bounces just a bit less.There is enough fricton in the spring leaves to make shocks not all that necessary.
#33356 07/25/2003 12:18 PM
Junior Member
Junior Member
got the king running today and went for a couple of laps round the property,at 30 mph hit a rut and nearly hit the roof!it bounced like crazy so i reckon some brackets off the bottom of the spring shackle and run some tube shocks up to the frame.just the front-the rear is probably not worth it you wouldnt budge that spring pack with 5 ton on it!!
thanks for the replys everyone.
