1 members (Rusty Rod), 80 guests, and 2 robots.
Topics128,127
Posts1,056,680
Members48,452
Junior Member
Junior Member
I searched and found the firing order for my 62 235 Cheby engine.
153624
But being a V8 **** guy, I'm not sure which one Chrvy calls number 1, near radiator or near transmission.
Any help appreciated.
62 1/2 Ton Stepside, 3 on the tree and 235 I6
Grandpa gave it to me, it is straight and original with about 90K original miles..
H Online: Content
#1 is at the radiator end!
Junior Member
Junior Member
Thanks, that might explain why she's not running :-)
The distributor rotates clockwise.
Paint & Body Shop moderator
Junior Member
Junior Member
4onthefloor, you're on top of the game...I was just thinking that I need to confirm the direction of rotation! Although I was just spinning it with teh cap off. It's sparking well (reman dizzy, new coil, good wires). It looks like fuel is getting to the carb, may be old fuel, but it's getting there.
Now, I've got all the info I need except how to get #1 TDC. How do you guys manually turn the crank. I could not get a socket to grab a crank bolt inside the balancer like I would do on my ***** . I can hit it with the staret, but I can't really tell where it's stopping, Russian Roulette.
H Online: Content
Pull all the spark plugs, and turn the fan. (Clockwise from the front!) With a tight fan belt, the engine should turn. Another method is to put the truck in high gear, and gently roll it forward until #1 rolls up to TDC. BTW, the timing mark comes up twice, once at the top of the compression stroke, and again at TDC on exhaust. One of our guys here spent a couple of weeks figuring that one out! Be sure both valves are closed on #1 when you line up the timing mark!
I said that because it bit me before. The last engine with a distributor I had before that rotated counterclockwise.
Junior Member
Junior Member
Thanks guys. I had to punt on the old Chevy. I'll go back to figh that battle again with some charged batteries.
I went to work on one of my other projects. I at least got it to run. Still can't drive it, but it runs :-) Out of 3 old trucks, I've goy one running motor and no driveable trucks. It wouldn'e be so bad, but my main project has over $10K in the motor alone (no, not running :-(....
The wife is just shaking her head. "You mean, we've got 3 trucks, but I f I want a new dishwasher I have to get it delivered".....
Quote
To add to this, if you have the plugs pulled, you should be able to put your finger over the #1 plug hole and turn the motor over with the fan. When you feel the compression move your finger away from the hole, this is the compression stroke. Continue rotating until the TDC mark is lined up. If you can't find the TDC mark, rotate until no more compression is felt. That will be close enough to set the distributor rotor to point at #1. It otta fire right up from there.
