| | | Forums66 Topics128,051 Posts1,055,732 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Im looking at a 3 speed with overdrive and was curious what ya'll think would be its worth? How much should I be willing to go up to? It a 1958 3 speed with overdrive, so I thought that would be perfect for my truck. I was thinking of up to $200.
58' 3200 235 3-speed/OD
| | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Sounds about right. One thing about these is the parts are hard to find. | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Which parts do you mean? I would think it would bolt right up to the bellhousing, all I would need to do is shorten the drive shaft.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | parts like the solenoid, kick down switch, and any internals if it needs any repair ... shouldn't have to change anything, it's a direct bolt in replacement ... and FYI "C-3200" doesn't apply to the TF series, the C and K designations started in the 60's, the truck is a "3B" [long 1/2T] 3200
Bill | | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Bill is correct, the main transmission parts are readly available the problem is finding the parts for the OD or the rear section of the trans. Like the solenoid, govener, or internal parts. The kick down switch you can use any momentary contact switch that can be adapted to the carb. I have found that you can repair the govener, the big issue is the solenoid. Tom | | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | All I can say is that you are going to love it. I now have 7 years on a '62 3sp+od, non-sychro 1st gear. Cruise easily @ 70-75 mph, good fuel mileage..........(.70 X 3.90 = 2.73 final drive in 3rd od)
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Nov 2004 Posts: 2,402 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,402 | Bell Housings, kick down switches, solenoids, non-synchro 1st gear?? I am getting confused, is this topic about manual, or automatic transmissions? :confused:
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | John - this topic is about the manual overdrive trans, all of which pre ~1968 had no 1st gear synchro, and all of which require ways to control engagement/disengagement of the OD function - specifically the solenoid and kickdown sw
Bill | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Well I bid on it and did not meet the reserve(which I don't understand why people make a reserve anyways. If you want a minimum price then set that as the starting bid? Right?) So I didn't win because of that. It would be sweet to have it I know, I would save so much on gas and be able to get around alot faster. Well see what happens.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you don't get the trannie, they do pop up at the swap meets. I've bought 2 of them at 2 different swap meets over the years, and could have got a 3rd one when I got that 2nd one. Don't limit yourself to just truck versions. They were very popular in passenger cars, too. Same transmission, the only difference I can see is the speedo gear is set up for 4.10s instead of 3.90.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | 55-65 are non syncro, 66-69 are Saginaw full syncro units. Just get the most complete one you can. Sometimes you can get lucky and everything works. I have repaired many solenoids and govenors and aftermarket electrical components are available. Lots of info on this site about this subject. Fred
