4 members (Shaffer's1950, BC59, homer52, UtahYork), 98 guests, and 2 robots.
Topics128,038
Posts1,055,590
#331229 10/31/2007 10:38 PM
It has been about 10 years since I lasted removed the flywheel from my truck and I don't remember how. Obviously, my memory is starting to slip me. Transmission and clutch are both out of the way. I removed the bolts that hold the flywheel to the back of the engine, but it wouldn't budge. Put the bolts back in place----just in case.
I have also pulled the oil pan, but that is for a different reason. Do I have to remove the 2 bolts on the bottom of the engine by the rear main seal to get the flywheel off??
All help is greatly appreciated.
Kent Butler
'56 Chevy 3100
Houston, TX
Riding in the Passing Lane
Put 2 bolts in part way. Put a pry bar or 2 between the engine & flywheel & pry back & forth.
1972 Chevy c10 Cheyenne Super
no,no no. what the hell are you doin.Just smack the flywheel with a dead blow hammer.the bolts are out of t he flywheel?????.you better get the mind working.also check the pilot bearing.???????????.that,s is
the crankshaftsounds to me ya better r have someone do the job for yyyaaaaa.how old are ya fellow??????????.You know the mind say,s yes .but the body just can,t doit
dan-pa
dan-pa #331269 11/01/2007 12:17 AM
NO.NO
dan-pa
dan-pa #331324 11/01/2007 2:01 AM
The flywheel is piloted on the crank, and most likely held in place by rust. I leave one bolt in a few threads, or use a chain and retain the FW to the block. Then use a section of 2x4 and a fist-maul. put the 2x4 up against the edge of the FW and smack it. Same principle as deadblow hammer.
Flywheel then comes of, if you dont retain it, it lands on your foot, then rolls down the driveway into oncoming traffic.
If you use a prybar, be careful or things may break. a hearty smack vibrates the thing off. prying works if you slowly work from side to side.
Scott
Thanks to everyone for the comments and help. Flywheel is now off and on its way to the machine shop.
Kent
Did it bounce off your foot before rolling into the traffic?
ROFLOL....
Mine did that, and it was the 13" brown/lipe style from a big truck 302. I have teeth marks in my Wesco boots from that.
Paint & Body Shop moderator
