7 members (klhansen, Otto Skorzeny, MickeyP, DadsFirstPickup, Woodcmiami, Hotrod Lincoln, Wayne67vert),
73
Mod | | | Forums66 Topics128,043 Posts1,055,609 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33095 03/02/2005 4:55 AM | Joined: Jul 2004 Posts: 46 Junior Member | | Junior Member Joined: Jul 2004 Posts: 46 | I took my truck on a 20 mile drive the other day down to the body shop. After i got off the freeway and pulled in i backed up and the chatter was so bad i almost got whiplash. I pulled forward and it did it as well, but is way worse in reverse. I dont notice it much when i just drive it on short drives. Do you think a long drive could cause this? Clutch not adjusted properly and is slipping on the freeway? I would think if it was slipping for 20 miles it would be so burnt or glazed that it wouldnt work at all. Any insight on this? thanks | | |
#33096 03/02/2005 4:58 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Is it possible it's oil soaked? I'm fixing that same problem on my father-in-laws 55 Ford now. Scott | | |
#33097 03/13/2005 9:43 PM | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | All old fords do that. It is caused by oil on the clutch. It doesnt take much.
I like old trucks
#33098 03/14/2005 5:09 AM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | The clutch in my 37 is chattering,the rear main on the 235 is leaking a bit. | | |
#33099 03/14/2005 3:56 PM | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I've had the same experience as the other posts, oil on the clutch. This is pretty classic from what I can tell, leaky rear main resulting in chattering clutch. | | |
