2 members (Uncles51, Lostbuthaulinass), 79 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#33095 03/02/2005 4:55 AM
Junior Member
Junior Member
I took my truck on a 20 mile drive the other day down to the body shop. After i got off the freeway and pulled in i backed up and the chatter was so bad i almost got whiplash. I pulled forward and it did it as well, but is way worse in reverse. I dont notice it much when i just drive it on short drives. Do you think a long drive could cause this? Clutch not adjusted properly and is slipping on the freeway? I would think if it was slipping for 20 miles it would be so burnt or glazed that it wouldnt work at all. Any insight on this? thanks
#33096 03/02/2005 4:58 AM
Is it possible it's oil soaked? I'm fixing that same problem on my father-in-laws 55 Ford now.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#33097 03/13/2005 9:43 PM
All old fords do that. It is caused by oil on the clutch. It doesnt take much.
I like old trucks
#33098 03/14/2005 5:09 AM
The clutch in my 37 is chattering,the rear main on the 235 is leaking a bit.
#33099 03/14/2005 3:56 PM
I've had the same experience as the other posts, oil on the clutch. This is pretty classic from what I can tell, leaky rear main resulting in chattering clutch.
