1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#33048 02/01/2004 5:09 AM
Hi all...
I just got done building my engine hoist earlier today smile smile . Well, OK, it's not 100% done, it lacks the final touch of some primer and paint. You can see it here.
I used 3" x 3/16" square stock for the main parts and 2.5" x 3/16" square stock for the inner adjustable pieces, such as the leg extentions and extendable boom. All pins and reinforcing plates are stainless steel. The casters are industrial type (ball bearing swivel, neoprene wheels with a solid steel center hub) that I got for free grin grin grin . The whole unit was TIG welded using a Miller TIG outfit.
Take a peek...
Thanks, in advance!!!
Burgie
1964 Chevy C60 w/ Garwood dump, 327 CID, New Process 540C 5-Speed w/ Chevy 15,000 lb. 2-speed rear axle
1966 Chevy C60 w/ 292 CID, Chevy 4-speed w/ Chevy 15,000 lb. single speed rear axle
[b]Burgie's 1964 Chevy C60 Restoration Site[/b]
#33049 02/01/2004 7:34 AM
Looks good may have to have you send me a copy of your blueprints.
Collecting is fun, as long as momma enjoys riding in them.
#33050 02/01/2004 2:45 PM
Hi Burgie
Looks great. My hoist is basically the same, may be a bit heavier build, but I found that the vertical beam needs side support. You are only secured with those two bolts onto the lower x member.
I have a bolt just under the pivot point where I attache two flatbars down to the outside of the lower frame.
Check this link or go to my website and find the section attaching body to frame.
http://www.badmileage.com/Truck/Body_to_frame/Cab%20on%20Frame.JPG
I always try to have the bolts coming from the top down, should I loose a nut, there is always a bolt to keep the junk together.
I wish my welding would be as good as yours
Fritz
Fritz Peyerl
Turner valley, Alberta
