1 members (JW51), 186 guests, and 1 robot.
Topics128,081
Posts1,056,077
Members48,434
#32887 12/20/2004 8:36 PM
Junior Member
Junior Member
I'm considering going to a single two barrel carb on a my 66 chevy truck. It has a 230 from a 63 truck installed. I currently have a Offenhauser 2x1 intake with headers and 2 1bbl Rochesters. I am looking more for drivability.
I'm considering having the stock ehaust manifold split at Kansas Kustoms, placing the original intake back on and going with a reliable 2 barrel. Any thoughts or recomendations?
I don't think they'll split that manifold for you. Not good metal, cracks easy and hard to weld. I'd go for the cast iron headers from Langdon's.
I don't know what 2 bbl to recommend but, I can say I had bad experience with several variations of the Rochester 2G.
You should email about your exhaust manifold and be prepared for plan B.
-David
Kustoms-and-Sleds
Tradin' up dimes for nickels...
My \'65 Chevy C-20
The 2G is a mixed blessing. Holley makes a 2 bbl that should be pretty good. I had an 80 van with a 25 and progressive Rochester 2 bbl that worked pretty good. Got about 18 mpg with it.
Last I knew, Kansas Kustoms would not split headers from the later sixes due to crappy material.
Fred
52 3600
69 C-10
#32890 12/21/2004 11:26 PM
PLease keep us posted as to what you do, as I have a 68 250 that is bone stock now, that I want to upgrade to a holley or?? and duals?? Thanks, Garry K
1948 Chevy 235 SM-420 Stock
1965 Monster Datsun 4x4 with Chevy 250, 4spd and rockwell xfer
Garry K in Pac Nor West
1948 Chevy PU 235 SM420 4 spd
1932 **** B pu
1964 Datsun 4x4 with SBC, SM465 4spd and Rockwell xfer Dana 44Fr and 12 Bolt Rr.
For drivability the Holley / Weber 5200 is tough to beat. However, it is a pretty small carb. compared to running dual rochester singles you would loose some horsepower. But, you can't beat 'em for cold starting and just all around runnning good. Pretty good mpg too as long as you don't get to heavy footed.
Boo
We don't need no stinking V-8s!!
