2 members (2-Ton, farmallb),
62
Mod | | | Forums66 Topics128,021 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | Can anyone expand on this technique of tweaking the doors to make them flush? I read the maintenance manual and it said to pull the bottom of the door in, you have to bend the hinges. In this old post, some said to use a 2x4 block to bend the whole door. Where do you put the block? Wouldn't this hurt the door panel? I'm going to take pictures of the one door I have installed with a good gap at the bottom that I can't figure out how to align it. AD Door alignment Thanks for the help. | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | | | | | Anonymous Unregistered | | Anonymous Unregistered | To get my right side door to line up after swapping hinges I had to heat the straps red hot top and bottom and then man-handle it into position. This was done only after all other adjustments were attempted. Doors work fine now. This method though is not suitable it you have everything already painted. | | | | | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | Chuckthetruck, You seem to have been here before. I took a close look at my right door this afternoon. With no weatherstripping installed yet, only the rear bottom of the door is sticking out. How do I fix that?
Thanks, RedGreen | | |
