2 members (Hotrod Lincoln, latroca52), 73 guests, and 5 robots.
Topics128,024
Posts1,055,395
Members48,422
#327983 08/14/2007 12:36 AM
Can anyone expand on this technique of tweaking the doors to make them flush? I read the maintenance manual and it said to pull the bottom of the door in, you have to bend the hinges. In this old post, some said to use a 2x4 block to bend the whole door. Where do you put the block? Wouldn't this hurt the door panel? I'm going to take pictures of the one door I have installed with a good gap at the bottom that I can't figure out how to align it.
AD Door alignment
Thanks for the help.
1950 Chevrolet 3100 "One Step Forward, Two Steps Back"
Webshot Photos
#327984 08/14/2007 11:30 AM
#327985 08/14/2007 2:12 PM
Anonymous
Unregistered
Anonymous
Unregistered
To get my right side door to line up after swapping hinges I had to heat the straps red hot top and bottom and then man-handle it into position. This was done only after all other adjustments were attempted. Doors work fine now. This method though is not suitable it you have everything already painted.
#327986 08/19/2007 12:12 AM
Chuckthetruck, You seem to have been here before. I took a close look at my right door this afternoon. With no weatherstripping installed yet, only the rear bottom of the door is sticking out. How do I fix that?
RedGreen
Webshot Photos
