| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | I bought a piece from Jim Carter that keeps the door from swinging forward to far! One door is fine, but the driver side door is missing the piece the pin fits in that attaches to the door. What do they call the piece? I notice two small slots in the door that something fits in to drop the pin through? Where do you find one?? I'm lost!(GRIN)
Dan Mascheck | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Did you get an answer? I've got those things but haven't installed the doors yet. I'd like to get an answer also. | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | They have a piece you can either weld to the door or as one guy said drill holds and bolt it on. I will repaint mine in a year, so I will wait and weld it on before the repaint!
Mine has two slits on the door which makes me believe the original had two tabs that stuck through the slots and bent down inside the door! I need to look at the one door that has the compete setup!
Dan Mascheck | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I have four of those brackets that mount on the top hinge of the doors. There are two holes in the hinge and two holes in the swing arms that hold the restricting (door hold open springs) brackets or arms in place. I think you have to remove the hinge pin in order to install the arms. I found holes in each top hinge to mount the springs but don't know anything about the need to weld them. Are we talking about the same parts? Here is a picture of the door hold open springs that I have: http://www.americanclassic.com/images/dp238.gif | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | I don't know what model you have, but on a 46 Chevy the bracket that holds the door open is entirely different. It has a rubber end and you have to insert it through the kick panel area.
There is a plate with two loops that the bracket has a pin that secures it to both areas. I wish I was more articulte in describing what I am talking about! Look in the Jim Carter site or catalog for a 46 or later truck and you will see what we are talking about! I think they call it a door check! | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I thought we were both talking AD trucks. Mine is a 51.
Sorry... | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | No problem. I'm sure your right on a newer truck, but mine is a 46! Big difference! | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 |
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | |
