4 members (Shaffer's1950, Oswald, JJs55210, 1 invisible), 41 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#327788 05/08/2007 11:47 PM
I bought a piece from Jim Carter that keeps the door from swinging forward to far! One door is fine, but the driver side door is missing the piece the pin fits in that attaches to the door. What do they call the piece? I notice two small slots in the door that something fits in to drop the pin through? Where do you find one?? I'm lost!(GRIN)
Dan Mascheck
#327789 05/26/2007 12:10 AM
V
V Offline
Did you get an answer? I've got those things but haven't installed the doors yet. I'd like to get an answer also.
#327790 05/26/2007 2:24 AM
They have a piece you can either weld to the door or as one guy said drill holds and bolt it on. I will repaint mine in a year, so I will wait and weld it on before the repaint!
Mine has two slits on the door which makes me believe the original had two tabs that stuck through the slots and bent down inside the door! I need to look at the one door that has the compete setup!
Dan Mascheck
#327791 05/26/2007 3:40 AM
V
V Offline
I have four of those brackets that mount on the top hinge of the doors. There are two holes in the hinge and two holes in the swing arms that hold the restricting (door hold open springs) brackets or arms in place. I think you have to remove the hinge pin in order to install the arms. I found holes in each top hinge to mount the springs but don't know anything about the need to weld them. Are we talking about the same parts?
Here is a picture of the door hold open springs that I have: http://www.americanclassic.com/images/dp238.gif
#327792 05/26/2007 11:38 AM
I don't know what model you have, but on a 46 Chevy the bracket that holds the door open is entirely different. It has a rubber end and you have to insert it through the kick panel area.
There is a plate with two loops that the bracket has a pin that secures it to both areas. I wish I was more articulte in describing what I am talking about! Look in the Jim Carter site or catalog for a 46 or later truck and you will see what we are talking about! I think they call it a door check!
#327793 05/26/2007 2:23 PM
V
V Offline
I thought we were both talking AD trucks. Mine is a 51.
Sorry...
#327794 05/26/2007 7:40 PM
No problem. I'm sure your right on a newer truck, but mine is a 46! Big difference!
#327795 06/21/2007 7:01 AM
The pieces you are talking about are:
Door Hold Bracket to be welded inside door
Door hold spring
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
