1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 25 Junior Member | | Junior Member Joined: Nov 2006 Posts: 25 | I would imagine others have run into this problem. 66 step-side. I have to "lift up" on the door to get it to close smoothly. I am wondering if the pins on the hinges are worn from years of opening and closing. Just wondering how I should attack this issue. Would love to have smooth opening and closing doors! Thanks for any advise. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | From any one of the vendors that cater to the 60 - 66 trucks, order a set of hinge pins and bushings. They'll fix that sagging door right up. They will be a little tough to get apart but not a problem to reassemble, Scott | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | sometimes you can move the top hinge forward or the bottom hinge rearward to compensate for the hinge wear.it worked great on my 84 camaro. | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I worked in the body shop at a Chevy dealership in the 1970's & 80's and used to replace hinge pin/bushings all the time. Not a big job and the bushings are not expensive. Well worth the money for the improvement. If let go too long, the next thing to go will be the door lock & striker. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | |
