1 members (dt235sd), 60 guests, and 1 robot.
Topics128,080
Posts1,055,956
Members48,430
#327695 02/10/2007 10:07 PM
I am rebuilding the doors on my 49 Burb.On the passenger side door the channel closest to the front appears to have broken due to fatigue etc. at the bottom of the channel where it attaches to a bracket inside the door. It is loose banging around the bottom of the door. I looked at the driver door and it looks to have been spot welded from the factory. No way I can get a welder in there to reattach. Any ideas on best way to reattach. Would JB Weld work?
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
#327696 02/11/2007 12:16 AM
I
I Offline
Been there and done that. Our 47 had the same trouble. I got down inside the empty door shell and pop rivited one from another truck in it place. It going to be a *****, but you'll live though it. Remember to get rid of all the old one. Its spot welded at the top and the bottom both. I took a dremil tool, ground and cut out the old parts. May take an hour or so to get it all off, as here hardly any room to work. When drilling the rivits inside at the bottom, I had dennis look down though the top and tell them where I was at. Drill the holes in the lower end of the channel before you put it inside the door, so then you only have to drill though one piece of metal. I used a very small vice grip clamp to hold it to the bracket before drilling. Try to find a steel pop rivit, not an alumnum one.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#327697 02/11/2007 1:33 AM
Can you drill the spot weld out and do a plug weld to reattach it?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#327698 02/11/2007 7:39 PM
Thanks guys for the advice. I'm out to do battle with the door and see who wins,
#327699 02/14/2007 3:06 AM
wounder if someone could post a pic of the channel on the 49 doors and\or give a good measurement of it .i intend to make some new pieces for my doors witch are 54 doors witch i am changing to single glass thanks layback.
layback
