2 members (qside, 78buckshot), 76 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#327481 06/11/2006 4:58 PM
Junior Member
Junior Member
I have a '40 truck with a droopy drivers door handle, the spring that pops the handle back up is shot. How or what do I need to replace to perk up my handle?...
thanks
#327482 06/12/2006 5:12 AM
Welcome aboard, American Classie Truck phone
940 365-9786 part # DLRS36 $4.00 a pair. Web site
www.americanclassic.com You came to the right
place to get info. This is the best site for old
Stovebolt's. Good Luck and enjoy your new truck.
#327483 06/12/2006 12:10 PM
Junior Member
Junior Member
I had seen those, but there is a box behind the door handle that those springs sit in, and it looks as though the springs are spot welded to the box, don't know that I can replace just the spring.... help! was thinking I would need to replace the entire box?... thanks for any and all input...
#327484 06/13/2006 1:11 AM
its been a while since I worked on this model but I think its like the 37"s?? Is it truly the springs or is the "square hole" the handle goes through worn in one corner. IF it is you will have to build up that spot or do as someone here once said......they put the handle in a vice, heated it with a torch and "bent" it up some. Problem solved!!?? Just idea's Partzpllr, trying to help!!
#327485 06/13/2006 3:50 PM
I think my 46 is the same as your 40. I have a couple of pictures of the new springs and where they go on the latch assembly.
If you want them I can email them to you.
George
#327486 06/13/2006 4:33 PM
Junior Member
Junior Member
that would be wonderful, I will take all the help I can get.... please
[email protected]
thanks a million!
