3 members (55shaker, Greg_H, 1 invisible),
106
Mod | | | Forums66 Topics128,281 Posts1,058,472 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 6 Junior Member | | Junior Member Joined: Jul 2004 Posts: 6 | I have a '40 truck with a droopy drivers door handle, the spring that pops the handle back up is shot. How or what do I need to replace to perk up my handle?... thanks | | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 85 | Welcome aboard, American Classie Truck phone 940 365-9786 part # DLRS36 $4.00 a pair. Web site www.americanclassic.com You came to the right place to get info. This is the best site for old Stovebolt's. Good Luck and enjoy your new truck. | | | | | Joined: Jul 2004 Posts: 6 Junior Member | | Junior Member Joined: Jul 2004 Posts: 6 | I had seen those, but there is a box behind the door handle that those springs sit in, and it looks as though the springs are spot welded to the box, don't know that I can replace just the spring.... help! was thinking I would need to replace the entire box?... thanks for any and all input... | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | its been a while since I worked on this model but I think its like the 37"s?? Is it truly the springs or is the "square hole" the handle goes through worn in one corner. IF it is you will have to build up that spot or do as someone here once said......they put the handle in a vice, heated it with a torch and "bent" it up some. Problem solved!!?? Just idea's Partzpllr, trying to help!! | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I think my 46 is the same as your 40. I have a couple of pictures of the new springs and where they go on the latch assembly. If you want them I can email them to you. George | | | | | Joined: Jul 2004 Posts: 6 Junior Member | | Junior Member Joined: Jul 2004 Posts: 6 | that would be wonderful, I will take all the help I can get.... please [email protected]thanks a million! | | |
