4 members (dogdaddy, Ponchogl, 2-Ton, 1 invisible), 72 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#32720 05/10/2004 9:23 PM
Junior Member
Junior Member
1 Offline
Hey. Im brand new to the boards so go easy on me LOL. I have a restored 1978 GMC Sierra Classic shortbox pickup. I recently pulled the engine out and put on some upgrades. I put a new energizer cam in, new intake, and headers. I figured it would have a lot of power but it seemed to have lost some. I figured it was running way to lean with the intake and header combo. I changed the jets from .064's to .071's. This helped on the mid to high end but it was still doggy on the low. Then I put in some 44B metering rods. This helped low end but it still doesnt seem to have the "get-up-and-go" like it should.
It has true duals and glasspacks, with no H-pipe.
I was wondering what you guys would reccomend for me so I can achieve the power I know its cpable of. I've thought about acuall mufflers to increase backpressure?
any help would be appreciated.
Thanks, Dustin
I Love My Truck!
#32721 05/10/2004 10:22 PM
Dustin Welcome: We need to know the engine size to make an educated guess. Sounds like not enough gas did you change carb size also. You add intake and cam w/headers it problay starving for fuel. popcorn The truth is Out There (your on the right track for HP)
#32722 05/11/2004 3:07 AM
Junior Member
Junior Member
1 Offline
Duh..sorry, my bad. Its a 350. The intake is an edelbrock S.P.2-P. My dad had it lying around in our shop that he had on an older car that he let me use. The cam is a crane cam energizer. The duration is 260. Oh, and I have the stock Q-jet still with the different jets and metering rods as i mentioned above.
that should help smile
I Love My Truck!
#32723 05/11/2004 3:39 AM
Sounds like wrong gearing for low end launching. What rear ratio are you running?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#32724 05/11/2004 8:12 AM
What is the timing set at and how did you set it?
How well did you adjust the carb and what method did you use?
Did you use a new timing chain and gear set?
if you used a new set, did you allign the marks properly?
Just questions to help us help you cool
#32725 05/12/2004 2:29 AM
A cammed-up smallblock will benefit from increased initial ignition timing, BUT, you have to restrict the travel of the centrifugal advance weights in the distributor by an equal amount. This is a trick I use on the round track engines I build. I don't reccomend doing it unless you have access to a distributor tester to check your work, but generally, a 5 to 6 degree increase in initial timing, and the same drop in centrifugal advance gives a better launch.
Alternate suggestion- - - -drop to a lower ratio rear end gear for better low-end acceleration.
#32726 05/12/2004 3:48 AM
Junior Member
Junior Member
1 Offline
There is a new timing chain and gear in the engine, I never messed with the timing, guess I never really thought of it :confused: With the carb I just put the different jets in and metering rods. Never really messed with the mixture screws. The timing gears are aligned properly. The gear ratio is 3:08. And my tire size are 235/70/15, I was thinking about going to a 235/60/15.
smaller tires would give me more grunt, but I would give up a little on my top end.
It seems to run alright with the 71s in the carb, I just need some help with finding more low end, Some trucks my year came with .074's stock. Would that help?
Thanks for all your help by the way.
-Dustin
I Love My Truck!
