| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#32720 05/10/2004 9:23 PM | Joined: May 2004 Posts: 9 Junior Member | | Junior Member Joined: May 2004 Posts: 9 | Hey. Im brand new to the boards so go easy on me LOL. I have a restored 1978 GMC Sierra Classic shortbox pickup. I recently pulled the engine out and put on some upgrades. I put a new energizer cam in, new intake, and headers. I figured it would have a lot of power but it seemed to have lost some. I figured it was running way to lean with the intake and header combo. I changed the jets from .064's to .071's. This helped on the mid to high end but it was still doggy on the low. Then I put in some 44B metering rods. This helped low end but it still doesnt seem to have the "get-up-and-go" like it should. It has true duals and glasspacks, with no H-pipe. I was wondering what you guys would reccomend for me so I can achieve the power I know its cpable of. I've thought about acuall mufflers to increase backpressure?
any help would be appreciated.
Thanks, Dustin
I Love My Truck!
#32721 05/10/2004 10:22 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Dustin Welcome: We need to know the engine size to make an educated guess. Sounds like not enough gas did you change carb size also. You add intake and cam w/headers it problay starving for fuel. popcorn The truth is Out There (your on the right track for HP) | | |
#32722 05/11/2004 3:07 AM | Joined: May 2004 Posts: 9 Junior Member | | Junior Member Joined: May 2004 Posts: 9 | Duh..sorry, my bad. Its a 350. The intake is an edelbrock S.P.2-P. My dad had it lying around in our shop that he had on an older car that he let me use. The cam is a crane cam energizer. The duration is 260. Oh, and I have the stock Q-jet still with the different jets and metering rods as i mentioned above. that should help
I Love My Truck!
#32723 05/11/2004 3:39 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Sounds like wrong gearing for low end launching. What rear ratio are you running? Scott | | |
#32724 05/11/2004 8:12 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | What is the timing set at and how did you set it? How well did you adjust the carb and what method did you use? Did you use a new timing chain and gear set? if you used a new set, did you allign the marks properly? Just questions to help us help you
#32725 05/12/2004 2:29 AM | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | A cammed-up smallblock will benefit from increased initial ignition timing, BUT, you have to restrict the travel of the centrifugal advance weights in the distributor by an equal amount. This is a trick I use on the round track engines I build. I don't reccomend doing it unless you have access to a distributor tester to check your work, but generally, a 5 to 6 degree increase in initial timing, and the same drop in centrifugal advance gives a better launch.
Alternate suggestion- - - -drop to a lower ratio rear end gear for better low-end acceleration. Jerry
#32726 05/12/2004 3:48 AM | Joined: May 2004 Posts: 9 Junior Member | | Junior Member Joined: May 2004 Posts: 9 | There is a new timing chain and gear in the engine, I never messed with the timing, guess I never really thought of it :confused: With the carb I just put the different jets in and metering rods. Never really messed with the mixture screws. The timing gears are aligned properly. The gear ratio is 3:08. And my tire size are 235/70/15, I was thinking about going to a 235/60/15.
smaller tires would give me more grunt, but I would give up a little on my top end.
It seems to run alright with the 71s in the carb, I just need some help with finding more low end, Some trucks my year came with .074's stock. Would that help?
Thanks for all your help by the way. -Dustin
I Love My Truck!
