3 members (1955 1 Series, Bill Hanlon, 1 invisible), 372 guests, and 4 robots.
Topics128,160
Posts1,057,054
Members48,463
#326711 08/06/2006 8:57 PM
Alright I started dinking with the radio on my 53'. It has 2 wires coming out of the box. Im assuming both of these are powered? 1 for the lamp and 1 for the radio? Does the box itself act as the ground when bolted to the dash?
Before I rewired the truck it had a faint hum when turned on but not wanting to blow it up I didnt leave it on for long. Ive heard these may need warmup time before working. Id like to see if it actually works before disassembling it.
Thanks in advance. Jeff
My 1953 Chevrolet
1947.1 Gallery
#326712 08/07/2006 12:26 AM
Ruste,
the two wires are indeed as you said. One wire, which should have an inline fuse, is used to power the radio and should be connected to the load side of the amp meter. The other wire should be run to the dash light supply on the headlight control.
There is a tech tip that explains the safe way to test out your radio. I think it might be good to read it before proceeding.
1951 1 Ton Completed
Moderated by  truckernix
