| | | Forums66 Topics128,162 Posts1,057,068 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 2 New Guy | | New Guy Joined: Aug 2007 Posts: 2 | I'm trying to completely hide the gas fill that will be used to fill a between the rails fuel cell under the wooden bed. I bought the kit from Mar-K with stainless strips. Is there a kit or does something need to be fabricated? | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | 58GMC I can't answer your question, but you might want to place this question in the "Making a Stovebolt Bed" section. It will get a little more attention there. Welcome to the bolt. There is a lot of great info on this site. It will take you a while to find it all. By the way I have a 59 gmc 1/2 ton.
John | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | i would say to make it it hidden you will need to FAB UP somethin ...maybe a nice trap door made out of the wood you will cut out ?...all you would see is the angle iron frame work an hinge an latch that would allow you to access the fuel cell filler ???? | | | | | Joined: Sep 2002 Posts: 4 New Guy | | New Guy Joined: Sep 2002 Posts: 4 | Try chevs of the forties I saw a stainlees pop up filler there yesterday
1936 1/2ton (awaiting restoration) 1938 1/2 ton (awaiting restoration) 1946 1/2 ton (under going restoration)
My wife is a shed Widow.....
| | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | | | | | | Joined: May 2007 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 36 | You can try (nolimit.com) as well. | | |
