4 members (1955 1 Series, tclederman, walter74, LAROKE), 133 guests, and 1 robot.
Topics128,122
Posts1,056,332
Members48,439
#32619 06/28/2003 8:41 PM
I've got a newly rebuilt rochester on my 235. It leaks like hell. After reading all the other post on this site it seems like this is just inherent in the design. I want to replace it with any other carb. I would like the cheapest and easiest to install, with no modifications if possible. What should I buy? Are any other decent carbs available that just bolt right on?
Thank-you for your help.
#32620 06/28/2003 9:13 PM
several places that you can go, jim carter, I got mine from RECARBO, I don't know how to hook you up to the link, just type in recarbo, I bolted mine on and never adjusted anything, I have had over a year. no problems and I drive my 52 halfton every day, it has a 54 235 eng, they can sell you dual carbs , anything you want ,I was real pleased with the service,good luck,,,FRED
Redryder pix
My Hotrod
#32621 06/29/2003 12:44 AM
ODSS President
ODSS President
I have one 2bbl Holley-Webber on my 235 half ton stock intake, Fentons, and get 17 mpg combined driving. Tom Langdon sells them for $65, 10 bucks for an adapter and another $15 for a good looking air cleaner with element. Lots of guys do the 2x2, looks good, performs well.
~ Cosmo
1949 Chevy Half Ton
#32622 06/30/2003 1:42 AM
I don't have a 235, but I just put an Edelbrock carb on my 350 ... right out of the box ... tuned up the air/fuel mixture screws *once* and I'm done with it. Easy as pie ... and I'm getting 16 mpg, too!
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#32623 06/30/2003 4:31 AM
I've got the 2bbl Holly-Weber and can say it is very reliable. And it doesn't leak. The motor usually starts on 1st try. Maybe 2nd in winter with choke pulled. you can get electric, water, or manual choke. I asked for manual but got water. It came broke but since I wanted manual I just took it off and twiddled bits until I got it hooked up. I don't really like the looks of it but it does work well.
40 Chevy 1/2 ton
#32624 06/30/2003 3:37 PM
I have a dual 2bbl Holly-Weber setup. I got the carbs & adaptors from Tom Langdon. I have been very pleased with performance and ease of set-up.
