| | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#32619 06/28/2003 8:41 PM | Joined: Dec 2001 Posts: 15 New Guy | | New Guy Joined: Dec 2001 Posts: 15 | I've got a newly rebuilt rochester on my 235. It leaks like hell. After reading all the other post on this site it seems like this is just inherent in the design. I want to replace it with any other carb. I would like the cheapest and easiest to install, with no modifications if possible. What should I buy? Are any other decent carbs available that just bolt right on? Thank-you for your help. | | |
#32620 06/28/2003 9:13 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | several places that you can go, jim carter, I got mine from RECARBO, I don't know how to hook you up to the link, just type in recarbo, I bolted mine on and never adjusted anything, I have had over a year. no problems and I drive my 52 halfton every day, it has a 54 235 eng, they can sell you dual carbs , anything you want ,I was real pleased with the service,good luck,,,FRED Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#32621 06/29/2003 12:44 AM | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | I have one 2bbl Holley-Webber on my 235 half ton stock intake, Fentons, and get 17 mpg combined driving. Tom Langdon sells them for $65, 10 bucks for an adapter and another $15 for a good looking air cleaner with element. Lots of guys do the 2x2, looks good, performs well.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
#32622 06/30/2003 1:42 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I don't have a 235, but I just put an Edelbrock carb on my 350 ... right out of the box ... tuned up the air/fuel mixture screws *once* and I'm done with it. Easy as pie ... and I'm getting 16 mpg, too!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#32623 06/30/2003 4:31 AM | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I've got the 2bbl Holly-Weber and can say it is very reliable. And it doesn't leak. The motor usually starts on 1st try. Maybe 2nd in winter with choke pulled. you can get electric, water, or manual choke. I asked for manual but got water. It came broke but since I wanted manual I just took it off and twiddled bits until I got it hooked up. I don't really like the looks of it but it does work well.
40 Chevy 1/2 ton
#32624 06/30/2003 3:37 PM | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I have a dual 2bbl Holly-Weber setup. I got the carbs & adaptors from Tom Langdon. I have been very pleased with performance and ease of set-up. | | |
