| | | Forums66 Topics128,159 Posts1,057,037 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 92 | Hey fellow bolters, I finally got the new bed installed. It was a longer process than I expected. It originally was going to be temporary (only for a few years till I got around to doing the frame off resto). I picked up the pine boards at H-Depot, ripped - routed - milled - stained - and sealed them. This was all possible with the help of (of course the Stovebolt Forums) GMCPauls Truck Parts and Mar-K I posted the pics on my CarDomain Site . I plan on putting a more detailed doc together for anyone else thinking of taking on this type of project. Just trying to give back a little of what I've taken from this site and all it's knowledgeable members. Thanks guys/gals, HC | | | | | Joined: Mar 2003 Posts: 315 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 315 | Great looking bed wood and even better that you did most of it yourself. Good Job! | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Great work. Looks real good!!! | | | | | Joined: Apr 2007 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 92 | Hey thanks guys, Like I said, it's the encouragement and support that helped me through this project. Plus the linked document on bed dimensions and the one from Mar-k on how to find the correct locations for the bed-to-frame bolts.
I also paid an unexpected price at the very end by throwing my back out moving that darn bucket of weights around. I used it to keep everything in place while I was underneath tightening everything up. Worked great too, till I was on the last few bolts - and bang! There goes my back.
The sacrifices we make . . . | | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | That looks awsome HC,,,Did you spray the boards??Or brush,,,
HURRY UP AND WAIT 55 235 3/4
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Frigin Awesome ! great Job ! | | | | | Joined: Apr 2007 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 92 | Mike G. I used the Helmsman Spar Urethane and for the stain I used a new one just out called 'Gun Stock' I applied a single coat of stain and three coats of spar top and bottom. The trucks garaged but if it were out in the weather more often, I would've put a few more coats on. | | |
