| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 110 | guys what can i mix up and spray on my wooden bed to stop mold from growing between the boards??? was thinking bleach and water??? blast it off with pressure washer but comes right back looks like mushrooms!!!! | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I would think Bleach and water mix should do the trick on mold. Might want to be careful with mold as my cousin used pressure washing on old mold growth on wood boats. He inhaled mold spores and had respiratory problems for years. He just died last Thursday at 56 years old. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | it worked on my house shingles | | | | | Joined: Feb 2007 Posts: 10 New Guy | | New Guy Joined: Feb 2007 Posts: 10 | The mold comes from the oak...usually if your bed is oak. Sometimes it may be ash as well. You can spray on a fungicide/bleach combination similar to antifouling compound from the bottom of boats but be very careful. The mold is bad, but so is the cure.
you have to watch bleach and water on an oak bed because the combination is acidic and it will turn the oak jet black where it contacts any iron...the bolts or ribs etc.
i usually mix the anti fungicide stuff in a mix of wd40 and brush it into the spaces...it penetrates and preserves and cures.
To restore an old truck is the work of a man...to restore a man is the work of God.
