| | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Yah, I know what your thinking! But no. I finally got the oak and stainless steel strips in the bed of the 50.
Have a look at the yahoo link. Wilbur | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Nice!!! What did you seal the wood with? I gotta re-do mine, and I'm looking for some opinions.
Bill Burmeister | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Mar-K has ongoing testing of several bed wood finishes. http://www.mar-k.com/wood_finish_testing_ii.html We coated test boards with ten different finishes and installed them in a test fixture outdoors with 24/7 exposure to the Oklahoma weather. In general, we have found that coatings need some kind of seal or primer coat for maximum durability. In the first series of tests, marine varnish by itself lasted only two or three months before defects appeared. The same varnish applied over epoxy lasted nearly a year. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I copied and pasted the reply above from an earlier post by Mar-K. This is good reading. I had a problem finding the marine primer I needed so I went ahead and used Spar Urethane. About 4 good coats on Oak wood. Looks great. I do keep my truck inside though. The frist time I did this it looked nice for about 3 years but it was exposed to the elements a lot. Read what Mar-K is doing and you will come up with the right answer for you. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I've actually been watching that test, so far everything I've considered using doesn't seem to have any durabilty to the elements. My truck is a daily driver, so it sits out in the sun, rain, etc. The only thing it doesn't see much of is snow. I just though I'd ask what others have had good results with before I taer mine apart to re-do it.
Bill Burmeister | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Originally posted by LONGBOX55: Nice!!! What did you seal the wood with? I gotta re-do mine, and I'm looking for some opinions. I used spar marine varnish. The truck won't see any harsh conditions as it's a fair weather truck. The oak boards were cut and milled by my father-inlaw from a tree on his tree farm that fell. (30 foot tall tree). | | |
