1 members (Bucker),
144
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Anyone ever tried using hockey pucks instead of wood blocks when mounting the bed? Pucks will outlast wood and there might be a little bit of give in them to make the ride a bit softer. I know that a lot of guys use them to jack their 4WD trucks up, | | | | | Joined: Oct 2005 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 16 | I used pucks in my 50 chevy and it worked just great.
cheap and long lasting | | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 |
Jim
Good luck with your project!
Jim
| | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | Don't do it. The pucks will fail on you. No one uses them on 4x4's anymore because they can't take the abuse. Use poly bushings from companies like Daystar, Prothane, MORE or original rubber bushings but not pucks. It just ain't right. PS: If you own a 63-72 pickup then check this out: http://www.tellico4x4.com/index.php/cPath/419_3007?osCsid=a94c2787259caf3006abc17247315c9e | | | | | Joined: Apr 2006 Posts: 20 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 20 | also if you are caught by the highway patrols doin a inspection you will get a very heavy fine for using none approved mount materials they will have a field day with you and the pucks | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Some interesting answers. I have decided to use the rubber pads. As far as highway patrol is concerned, we don't have to worry much about being stopped for a mechanical inspection. Half the vehicles up here have a burned headlight and have driven that way for years. No one even looks. Sad! | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Pucks should only be put in the net | | |
